DIAdem 2025 Q2: Graph & Axis Parameters Ignore Fractional Values
Updated Jun 15, 2026
  • DIAdem 2025 Q2
In DIAdem 2025 Q2, when a decimal number is entered in graph or axis settings dialogs, the value is automatically truncated to an integer once focus moves away from the input field, without any warning.
The behavior appears to be related to locale-dependent number parsing, where DIAdem does not correctly interpret decimal separators according to the system’s regional settings. Until a permanent fix is available, the following workarounds can be used to mitigate the issue.
Workaround 1: Change the Decimal symbol from “,” to “.” in Windows Settings > Time & Language > Language & Region > Number settings.
Workaround 2: Switch the operating system language to English from Windows Settings → Time & Language → Language & Region
