I am following the NI documentation to display terminals for a VI, function, or Express VI. The documentation states that I should right-click the block and select Visible Items>>Terminals.
However, when I right-click the block in LabVIEW, I do not see the Terminals option under Visible Items. I only see Visible Items>>Label, and the expected menu option is missing.
An example of this is the Read Single Element from Stream vi only having Label as an option under Visible Items:
