Using the “Open in DIAdem” Feature in SystemLink Enterprise
Updated Oct 20, 2026
  • DIAdem
  • SystemLink Enterprise
  • DIAdem SystemLink Toolkit
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
  • SystemLink
I see the "Open in DIAdem" option in the latest version of SystemLink Enterprise (SLE). How do I use this feature, and are there any known caveats or limitations?
Starting with the May 2026 SystemLink Enterprise release, the "Open in DIAdem" button is available in the Files section , allowing you to directly open files in DIAdem.
To use this feature, ensure the following software are installed on the local machine:
When a file is selected and "Open in DIAdem" is clicked, the file is downloaded locally to %LocalAppData%\National Instruments\DIAdem\CachedFiles and automatically opened in DIAdem.
 Note:
  • Users should manage this folder as the files are not automatically deleted.
  • The existing files may be overwritten without confirmation.
Caveats
  • DIAdem Instance Behavior
    • Each file is opened in a new DIAdem instance.
  • DIAdem Version Selection
    • If multiple DIAdem versions are installed, the latest version is used.
  • Data Portal Behavior
    • For performance reasons, files are registered in DIAdem's Data Portal.
    • Regsistered channels are read-only.
    • To edit, channels must be expanded.
  • Unsupported File Types
    • The application will download and launch DIAdem for all file types.
    • Unsupported formats or missing DataPlugins will result in standard DIAdem warnings.
  • Referenced files
    • All referenced files (for example, .index files for TDMS) must be present locally.
    • You can open referenced files using the "Open in DIAdem" before opening the main file, or manually download the referenced files into the CachedFiles folder.
  • Event Logging
    • Errors and warnings are logged in the Windows Event Viewer under Windows Logs >> Application, with Source as DIAdem SystemLink Toolkit.
  • File Name Conflicts
    • If a file cannot be overwritten in the download location, a new file is created with an index appended to the filename.
  • Path length limitations
    • Files exceeding OS path or filename limits (depending on Long Paths configuration) will not be saved.
  • Token expiration
    • Large files or slow downloads may fail with the following error when the download token expires.
The download request failed: The response ended prematurely. (ResponseEnded) for URI
    • Workarounds:
      • Download the file manually, or
      • Increase the SystemLink token timeout.
  • Connection Loss Behavior
    • If the internet connection is lost during download, the application may become unresponsive. Closing the dialog typically resolves the issue.
