Perform a Clean Uninstall of NI Software on Windows
Updated Oct 20, 2026
  • Package Manager
I am attempting to completely uninstall all National Instruments software and drivers from my system. Although I have removed the software using standard Windows uninstallation methods, I continue to experience installation failures and unexpected behavior when attempting to reinstall the software. The issue persists across multiple installation attempts, including the use of the repair option, and prevents me from successfully completing a clean installation of the National Instruments software. Are there any steps I can follow to remove these residual files without having to reimage my PC?
To completely remove National Instruments software and drivers from a Windows-based computer and prepare the system for a clean reinstallation, perform the following steps in the order listed below:
1. Remove all National Instruments software and drivers using NI Package Manager:
  1. Open NI Package Manager.
  2. Select the Installed tab.
  3. Select Settings (Gear icon).
  4. Enable Show Full Version Numbers and Hidden Packages.
  5. Disable Products only.
  6. Select all installed software and drivers, then click Remove.
    Note: You can also refer to the article "Removing NI Software Hidden Packages and Folders Through NI Package Manager" for reference.
  7. After all packages have been removed, open the Windows Control Panel, select the Uninstall a program option or Apps and Features, then select NI Package Manager and all NI software-related items. Please use the image below as a reference:
2. Delete residual files and folders using Windows File Explorer.
  1. Standard uninstall procedures may leave configuration files and other components on the system. To remove these residual files manually, enable Show hidden items in Windows File Explorer. You can refer to this external article if needed: How to turn on hidden files and folders on Windows-Autodesk.
  2. Navigate to each of the directories listed below.
  3. Delete the directory if it exists.
    • C:\Program Files\National Instruments
    • C:\Program Files (x86)\National Instruments
    • C:\ProgramData\National Instruments
    • C:\Users\<YourUsername>\AppData\Local\National Instruments
    • C:\Users\<YourUsername>\AppData\Roaming\National Instruments
3. Remove National Instruments registry entries using Windows Registry Editor.
Note: Back up the Windows registry before making any changes (How to back up and restore the registry in Windows). Incorrect modification can cause system instability, application failures, or prevent Windows from starting.
  1. Open the Windows Registry Editor.
  2. Navigate through the paths listed below and delete them if present.
    • HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments
    • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments
    • HKEY_CURRENT_USER\Software\National Instruments
    • HKEY_CURRENT_USER\Software\WOW6432Node\National Instruments
4. Reboot and reinstall NI software and drivers.
  1. Restart the computer to release any locked files.
  2. Install NI LabVIEW first if it is the Application Development Environment (ADE) used on the system.
  3. After the NI LabVIEW installation is complete, install all required drivers, such as NI-DAQ™ mx.
  4. Use offline installers (reference image below) whenever possible to avoid interruptions caused by network connectivity issues. Offline installers can be downloaded from the Software and Drivers Download page.
If any files remain after completing these steps, or if you still encounter issues when reinstalling NI software, please contact NI Support for further assistance.
