LabVIEW™ Load Error 1126 (0x466): VI Version Is Too Early to Convert
Updated Aug 28, 2026
When trying to open a VI in a newer version of LabVIEW, I receive the following error message:
Error 1126 (0x466): VI version is too early to convert to the current LabVIEW version.
The VI does not open, and I am unable to convert it to the currently installed version of LabVIEW.
This error indicates that the VI was saved in a LabVIEW version that is too old to be directly converted by the version currently being used.
To resolve this issue, use an intermediate LabVIEW version to progressively upgrade the VI:
  1. Determine the version in which the VI was originally created.
    • If the VI was created before LabVIEW 6.0, use an intermediate version between LabVIEW 6.0 and 8.2.
    • If the VI was created in a newer version, identify the latest LabVIEW version that can open the VI without displaying the error.
  2. Open the VI in the identified intermediate LabVIEW version.
  3. Save the VI in that LabVIEW version.
  4. Repeat the process as needed using progressively newer versions of LabVIEW.
  5. Once the VI opens successfully without error in the target LabVIEW version, follow the standard upgrade process described in Upgrade VI to a Newer LabVIEW™ Version to migrate the VI to the target version.
