Confirm NI DAQmx and LabVIEW compatibility
- Ensure the NI DAQmx driver version matches your LabVIEW version:
Please refer to this Knowledge Base article: NI-DAQmx and LabVIEW Compatibility - NI
- Update drivers if necessary to avoid communication errors.
Check physical connections
- Confirm the thermocouple leads are securely connected to the DAQ device.
Loose or reversed connections can cause unstable or incorrect readings.
Verify correct channel
- Make sure the VI is configured to read from the same channel where the thermocouple is physically connected.
- Double-check the NI DAQmx channel assignment in your LabVIEW project:
Run a NI DAQmx example
- Use NI’s built-in NI DAQmx examples for thermocouples to confirm the sensor works independently of your custom VI.
- Test the thermocouple in a known environment (ice water or boiling water) to confirm it responds correctly.
Please refer to this Knowledge Base article: How to Search DAQmx Examples in LabVIEW - NI
Select the right thermocouple type
- In the VI, choose the correct thermocouple type (K, J, T, etc.).
Using the wrong type will result in inaccurate temperature readings.
Test another channel
- If the reading is still incorrect, try connecting the thermocouple to a different channel to rule out hardware issues.
