I am using a PXIe-5105 and reviewing the recommended oscilloscope probes. According to NI documentation, the SP200B probe is listed as a compatible option. However, when I compare the probe specifications with the PXIe-5105 specifications, I notice that the probe compensation range for 1 MΩ input capacitance appears significantly different from the PXIe-5105 input capacitance. I would like to understand whether this behavior is expected and which probes can be used with the PXIe-5105.
