How To Create One Carrier aggregation Waveform in WLAN ?
Updated May 26, 2026
  • RFmx WLAN
  • RFmx Waveform Creator
If you wanted to create one Carrier Aggregation Waveform in WLAN , you find there is no feature supporting it in RFmx Waveform Creator for WLAN;
For example , below picture show one CA waveform which including two 160M WLAN signals with 320M offset. (blue or yellow signals together in the picture below):
How could you create above WLAN CA waveform and generate it out ?
1.Used RFmx Waveform Creator for WLAN to create one 160MHz standard waveform and save it as TDMS file;
 2.Select Multi-Carrier personality of Modulation to open Multi-Carrier Software Front Panel
  3.Open Add Carrier panel , then add the previous saved WLAN 160MHz standard TDMS file , and setting the key parameters , like Frequency Offset , Gain ,etc
4.Repeat step3 adding another TDMS file , then setting parameters for CA waveforms , like Sample Rate , Oversampling Factor and Sample Rate Mode;
5.Open Download & Play panel , generate the waveform after setting correct parameters;
Problem Summary RFmx Waveform Creator for WLAN not support Carrier Aggregation
Solution Summary  Used Multi-Carrier personality to create the WLAN CA waveform and Generating success; RFmx SpecAn can received the CA waveform in spectrum (refer to below picture);
KCS Rationale Needed
