NI-USRP 2026 Q1.
When trying to update the FPGA image of USRP X410 using NI-USRP Configuration Utility
The following error appears: Invalid FPGA firmware image file. Enter a valid file path to the image file.
This error is a known issue for NI-USRP 2026 Q1.
FPGA image can be updated using Command Prompt (CMD). Follow the instructions below to update the FPGA image
cd C:\Program Files (x86)\National Instruments\NI-USRP\utilities
uhd_find_devices.exe
uhd_image_loader.exe --args "type=x4xx,addr=<USRP IP address>" --fpga-path "C:\Program Files\NI\LVAddons\niusrprio\1\instr.lib\niUSRP\Reference FPGA\FPGA Bitfiles\X410ReferenceFpga_4ch_4spc.lvbitx"
