I am running multiple applications developed in LabVIEW, and after installing Cortex XDR version 9.1, I observe abnormal behavior in some of my systems.
The issue does not affect all applications, but a subset of 10-15 VIs, typically larger applications.
Observed symptoms include:
- Incorrect timing behavior in applications
- Unexpected changes in signal outputs
- Issues involving Timed Loops
- No crashes or blue screens, but incorrect execution behavior
The issue appears only with Cortex XDR 9.1
Downgrading to Cortex XDR 8.7 or 8.9 resolves the problem
Replacing Timed Loops with While Loops may temporarily resolve the issue
Disabling the antivirus does not fully eliminate the behavior in some cases
