I am using the Scanned Variable Write VI in LabVIEW to remotely write to the I/O variables available in my Ethernet expansion chassis. For instance, if I have an NI-9474 module inside my NI-9149 Ethernet chassis, I observe the following error running the code either on a Real-Time (RT) controller target (i.e., cRIO-9058) or in my host computer.
Error -1950678962 occurred at Scanned Variable Write in Main.vi
Possible reasons (s):
LabVIEW: (Hex 0x8BBB004E) The specified variable does not support the specified read, write, or open operation.
