Offline Installation of NI Drivers on OpenSUSE
Updated May 13, 2026
  • Linux
NI provides python script to clone or create custom repositories for use on offline systems. The script targets RPM-based Linux distributions supported by NI. This article explains how to use the script to create an offline repository for installing software from the NI Linux Device Drivers repository on ni.com onto an offline OpenSUSE system.
To create offline installation media, you will need a separate system that:
  • Runs the same Linux distribution as the target offline system
  • Has internet access to retrieve packages from NI repositories
Additionally, root privileges are required, and certain prerequisite software must be installed to ensure the scripts run correctly.
The Python scripts mentioned in the instructions are available for download at the bottom of this article.
  1. Configure the Host system to prepare for running the script
    1. This system should be running the same distribution as the target system and have an internet connection.  In addition, the host system should be up-to-date and the same patch version as the target system.
    2. Install the prerequisite software by running the following commands for the chosen distribution:
      openSUSE 15.5 / 15.6
      sudo zypper install python39 createrepo_c insserv-compat
    3. Register NI’s source repository with the system. Follow the steps to download and install the repository definition file for your system from NI Linux Device Drivers Download Page.  It is recommended to use the "static" repo type rather than the "stream" repo type for this process.
    4. Download the required Python script from this page that matches the Linux distribution of your host and target system.
      1. Change the permissions of the Python script so that it is executable:
        chmod +x offline_deb_repo.py or chmod +x offline_rpm_repo.py
  2. Use the script to clone the entire NI Linux Device Driver repository
    1. Using the attached Python script, you can clone the entire NI repository.  The following sections outline the commands necessary for each script to specify which repos to clone.
      1. Determine the name of the repo to clone.  Run the following commands to list all known and enabled repos on a system:
        sudo dnf repolist
      2. Run the following command from the directory where the script is located to clone the repository:
        ./offline_rpm_repo_opensuse.py -vvv repo --norepopath ni-software-2025
        • By default, the repo will be cloned to a subdirectory called "offline_repo" in the directory where the Python script is located.  If you'd like to change this, use the --output flag with a directory as the argument.
        • The -vvv flag increases the verbosity of the script and allows you to see the status of the download.
    2. When the download completes, you may notice an error reported by the script that a file named post-mirror.sh is missing from the /tmp directory.  This error is not fatal -- the download still completed successfully even if it is shown.
  3. NI products depend on some additional packages from the system repositories that are not installed by default.  If the target system is going to be truly offline, it will be necessary to download these package dependencies on the host system for installation on the target.
    1. First, clear the package cache so that older package or packages from other transactions are removed:
      sudo zypper clean --all
    2. Enter the following command to download all of the dependency packages as well as their dependencies:
      sudo zypper install --force --download-only dkms expat openal-soft bison flex kernel-debug-devel
    3. The packages will be downloaded to subdirectories in /var/cache/zypp/packages.  Copy the RPMs from this location to ~/offline-packages and move it to the offline PC
  4. Configure the target offline system
    1. Choose where the repository should be located on the target system.  Select a location where system users will not be able to accidentally delete the repository or modify its contents.  In this example, /srv/offline_repo will be used.
      1. Copy the offline_repo directory from the host machine to /srv using any standard file transfer method such as USB or a network share
      2. Copy ~/offline-packages from the host system to ~/offline-packages on the target system using any standard file transfer method such as USB or a network share
    2. Determine the name that you'll use for the repository.  This example uses ni-offline-software-2025.
      1. As root, create the repo file:
        sudo touch /etc/zypp/repos.d/ni-offline-software-2025.repo
      2. As root, edit the file:
        sudo nano /etc/zypp/repos.d/ni-offline-software-2025.repo
        and include the following text:
        [ni-offline-software-2025]
        name=NI Offline Software 2025
        enabled=1
        autorefresh=0
        baseurl=file:///srv/offline_repo
        type=rpm-md
        gpgcheck=0
        Press <CTRL-O>, followed by the Enter key to save the file, then <CTRL-X> to exit the editor.
  5. Install the dependency packages from offline-packages:
    • The directory ~/offline-packages should have been copied to the target in step 4
      cd ~/offline-packages
      sudo zypper --no-refresh install *.rpm
  6. If the target system will be used fully offline, the default repositories will need to be disabled. The reason for this is that zypper install command will continue to try to update the metadata for the online repositories which will time out and generate errors.  In some cases this will prevent package installation even when packages from the online repo are not required to complete the transaction.  By renaming the default repo files on disk, the repos are disabled in a non-destructive manner.
    Repo files are stored in /etc/zypp/repos.d
  7. Install from the new repository
    • At this point, the target system is ready to be used to install the offline software.  NI packages can be installed as if the system were connected to the internet.  For example:
      sudo zypper install ni-daqmx
Additional Information:
Script Help
The attached Python scripts are versatile and contain additional options to customize repository creation.  Pass the --help flag to the scripts to obtain a detailed list of the various options and capabilities the scripts provide.
