1. View the waveform parameters of the generation WLAN signal, below image show the WLAN waveform setting of RFmx Waveform Creator for WLAN :
As shown above picture , the WLAN signal is 802.11ax 20MHz, and the No. of Data Symbols setting is 95, meaning the WLAN signal contains 95 symbols.
2. To check the RFmx WLAN settings, the Maximum Meas Length needs to be greater than or equal to the RFSG side's No of Data Symbols value ;
As shown above image , the default value for Maximum Meas Length is 16 symbols, so this value should be changed to be greater than or equal to 95 symbols.
3. Enable Data Decoding Enabled feature in RFmx WLAN side , like below picture:
