I am unable to open or save a DBC file in NI-XNET Database Editor.
When opening a DBC file, I receive the following error:
An internal error occurred. Please contact NI and provide the logs found in "%LOCALAPPDATA%\National Instruments\NI-XNET\log".
In some cases, when saving a DBC file, NI-XNET Database Editor returns the following error:
NI-XNET: (HEX 0xBFF63132): Creating a database file failed. Solution: Verify access rights to the destination directory or check if overwritten file has read only permission.
