1. Accessory Contents
a. 782427-01:
• 4 × Ribbon Cable Assembly, RSH34 IDC (34-pin female), 100V, 17×2×0.05 position, 60-inch length
• 1 × Ribbon Cable Assembly, RSH16 IDC (16-pin female), 100V, 8×2×0.05 position, 60-inch length
b. 779346-01:
• 4 × Ribbon Cable Assembly, R34 IDC (34-pin female), 60V, 60-inch length
• 1 × Ribbon Cable Assembly, R16 IDC (16-pin female), 60V, 60-inch length
c. 782426-01:
• 1 × Ribbon Cable Assembly, RSH16 IDC (16-pin female, inverted), 100V, 8×2×0.05 position, 9-inch length
d. 779325-01:
• 1 × Ribbon Cable Assembly, R16 IDC (16-pin female), 60V, 9-inch length
2. Recommended Accessories for TB-2645B (As of May 2026)
a. Standalone Use:
If you plan to use the TB-2645B individually, each terminal block requires:
• 1 × 34-conductor ribbon cable
• 2 × 16-conductor ribbon cables
Therefore, for each TB-2645B, you would need to purchase:
• Either two sets of 782427-01, or two sets of 779346-01
b. Matrix Expansion (Two TB-2645B Units):
If you have two TB-2645B units and plan to perform matrix expansion between them, you would need to purchase:
• 2 sets of 782427-01 or 779346-01, and
• 2 sets of 782426-01 or 779325-01
