This issue can occur if NI services, drivers, or configuration data are corrupted or blocked by system security controls, preventing NI MAX from properly initializing or detecting PXIe hardware.
To help determine whether the issue is related to NI MAX software or the PXIe hardware itself, we recommend launching NI Hardware Configuration Utility (NI HWCU) or NI Hardware Manager. These tools can be used to detect the installed hardware and perform basic diagnostic checks, such as Self-Test, Self-Calibration, and Test Panel operations.
Please perform the following troubleshooting steps in order, starting with the least intrusive actions:
- Restart the computer and relaunch NI Measurement & Automation Explorer.
- Verify that the PXIe chassis and modules are powered on and physically seated.
Open Windows Services and confirm that the following services are running and configured with a Startup Type of Automatic:
- NI Device Loader
- NI Configuration Manager
- Restart NI Device Loader and NI Configuration Manager services.
- Open NI MAX and select View >> Refresh.
- Reset the NI MAX configuration database by selecting Tools >> Reset Configuration Data.
- Restart the computer when prompted.
- Open NI Package Manager and select Repair for the affected NI driver.
- If the repair process fails, temporarily disable any third-party antivirus, endpoint protection, or privilege-management software and try again.
- With security software disabled, ensure that all required NI drivers for the PXIe hardware are installed correctly.
- Restart the computer.
- Re‑enable security software and configure exclusions for NI installation directories and services.
After completing the above steps, NI MAX should launch normally, and the PXIe device should be detected, displayed correctly, and available for configuration. If the issue persists, please contact us and let us know the results of the NI Hardware Configuration Utility checks, including any Self-Test or Self-Calibration errors observed.
