I am acquiring data in FlexLogger using hardware such as the NI‑9234 module.
When I analyze the data directly in TDMS format, the signal looks clean and correct. However, after exporting the data to CSV, I observe unexpected artifacts in the FFT, such as:
- Sidebands around the main frequency peak with ~240 Hz spacing
- Apparent noise that is not present in the original measurement
- Differences between TDMS-based analysis and CSV-based analysis
This occurs when using high-speed acquisition in ~10 kHz range, especially when exporting data manually.
