When I try to View Data from a MySQL table using the TestStand Database Viewer tool, I get the following error:
An error occurred while opening a new tab
Error Details Index: #0
Message: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
ErrorCode: 0
Source:
Server: IM002
I’ve set up my connection with MySQL with the TestStand Database model plugin and I’m being able to write data and read them from the MySQL terminal and other clients. The problem is only with the TestStand Database Viewer.
How can I fix this error?
