I am using Advantech AIMB-505 and the PCIE-PXIE 8381 unable to function well in X16 slot but able to work in X1 slot.
This is due to the BIOS setting. Try to look for the following settings in BIOS:
Please note that every manufacturer have different BIOS settings and not every manufacturer BIOS contains the same parameter. NI advise user to check with the manufacturer.
