This usually occurs because the communication port is not specified in the license file when it differs from the default value of 4637.
To resolve this issue, you must specify the vendor port in the license file. The relevant entry is usually found on the second line of the license file.
Example below:
VENDOR nilm Port=[your specific port number]
