Correct Configuration Example:
To set a current limit of 50 mA, use the following configuration:
- Current Limit Range: 100 mA
- Current Limit: 50 mA
This configuration is valid and recommended, as the current limit value falls within the selected current range. You can set the Current Limit to 50 mA, but you cannot set the Current Limit Range to 50 mA; the Current Limit must always fall within a supported Current Limit Range, and the Current Limit Range itself must be set to one of the PXIe‑4140’s fixed hardware ranges.
