1. Copy the Excel Folder into the LabVIEW 2026 Installation
Locate the Excel folder from the Report Generation Toolkit add-on directory:
- C:\Program Files\NI\LVAddons\rgt\1\vi.lib\Utility\NIReport.llb\Excel
Copy the entire Excel folder to the LabVIEW 2026 vi.lib directory:
- C:\Program Files\National Instruments\LabVIEW 2026\vi.lib\Utility\NIReport.llb
Note: This ensures that LabVIEW 2026 can correctly locate the Excel-related Report Generation VIs and classes at run time.
2. In your LabVIEW project, add the following class manually:
- C:\Program Files\National Instruments\LabVIEW 2026\vi.lib\Utility\NIReport.llb\Excel\NI_Excel.lvclass
Save the project after adding the class.
3. Include the Excel Class in the EXE Build Specification
Open the Build Specifications for your EXE.
Navigate to Source Files.
Move NI_Excel.lvclass to Always Included.
Note: This step ensures that the Excel Report Generation classes are deployed with the executable.
4. Modify the Report Generation Toolkit Add-on Configuration
Open the following file in a text editor with administrator privileges:
- C:\Program Files\NI\LVAddons\rgt\1\lvaddoninfo.json
Locate the following content:
"AddonName": "rgt",
"ApiVersion": "v1",
"MinimumSupportedLVVersion": "26.0"
Change the MinimumSupportedLVVersion value from 26.0 to 24.0:
"AddonName": "rgt",
"ApiVersion": "v1",
"MinimumSupportedLVVersion": "24.0"
Save the file.
