In TestStand, even though the same Step can be executed and Pass or Fail multiple times (e.g. when using the Goto Flow Control step to execute the same Step again), if the Step fails at least once, its Sequence Status will be set as Failed.
Is this intended? How can I control the Sequence Status based on a repeating Step's result?
