Accessing Nigel™ AI Through Different NI Software
Updated Apr 21, 2026
  • Nigel AI Integration
  • TestStand
In this article, you will learn how to access Nigel AI through different NI software.
To access Nigel AI in LabVIEW™ or TestStand™ and then Log in you need to follow the next steps:
  1. Open the NI Nigel AI application.
    • In LabVIEW go to the icon that is either on the Front Panel or Block Diagram toolbar at the Top-Right Corner:
      You can also click on Tools >> Chat With Nigel AI...
    • In TestStand click on View >> Nigel AI to access to Nigel AI:
  2. Click Log in and sign in using your NI User Account.
  3. Authorize access if prompted.
Note: Nigel uses Auth0 for secure authentication. Your credentials are protected with industry-standard encryption and authentication protocols.
