In order to view the tabs , there are 2 method to enable it. You may follow below steps to add it in NI-FBUS Configurator.
Method 1 : Reset to default settings
- Click on Add or Delete Custom Tabs
- In Add or Delete Custom Tabs , Clicks Default to reset to default settings.
- It require to save and reopen it in order to take effect.
- Reopen and the Process and Diagnostics tabs will appear.
Method 2: Adding and configure manually
- Click on Add or Delete Custom Tabs.
- Add a new Tab naming as Process and Click OK.
- Click Customize Parameters and select which parameters you wish to add to the new created Tab.
- Close the windows and click Save the custom changes once done configure it.
