If your TestStand sequence file name includes non‑English or other Unicode characters, TestStand may have trouble processing them properly.
As a temporary diagnostic step, try toggling the “Use Unicode UTF‑8 for worldwide language support” setting in Windows, as referenced in the article “TestStand LabVIEW UI Crashes When Using Chinese Characters.”.
If the option is currently off, turn it on; if it is on, turn it off. Afterwards, check whether the TestStand crash still occurs.
If changing this UTF‑8 setting stops the crash, the root cause is related to Unicode encoding.
When the UTF‑8 option is disabled, Windows uses multi‑byte encoding; when it is enabled, Windows switches to single‑byte encoding. Since Unicode characters naturally require multiple bytes, they consume significantly more memory than standard English characters.
If Unicode characters are present in your TestStand sequence file name, TestStand may be unable to shorten or abbreviate the file path shown in the Most Recently Used (MRU) list under the File menu within the required byte limit. When this happens, the TestStand UI can become sluggish or unresponsive, ultimately resulting in a crash.
