Unfortunately, at the moment, LabVIEW Real-Time on Linux does not support Unicode encoding. Therefore, using Unicode-encoded characters, such as Cyrillic characters, will not work.
Refer to our recommendations below:
- Generally, we advise avoiding using a Front Panel on Real-Time (RT) targets in order to improve VI performance and maintain determinism. Instead of using Embedded UI or a Remote Front Panel, you can instead have a RT VI with no front panel, which shares data to a Host VI (running on a PC).
- For static text (such as Front Panel labels, instructions, etc.) you can paste images (PNG, JPG) onto the Front Panel or Block Diagram.
- You can control Front Panels of RT target VIs using a Remote Front Panel, an alternative to Embedded UI. If the LabVIEW Real-Time application's Front Panel is rendered by a Windows connection, then Windows can render Unicode text correctly.
