Configuring IT Network Settings for Accessing Nigel™ AI
Updated Oct 12, 2026
  • Nigel AI Integration
What network and firewall settings are needed to access Nigel AI?
Ensure the PC allows the following NI URLs and ports through the firewall:
    • delta.ni.com - Port 443
    • download.ni.com - Port 80
    • ni.com - Port 80
Whitelist the following URLS in proxy servers, SSL Inspection, firewalls, and in any other relevant security software:
    • *.emerson.com
    • *.digicert.com
    • https://tnm.emerson.com
    • https://crl3.digicert.com
    • https://crl4.digicert.com
    • https://ocsp.digicert.com
Add TLS exceptions for the following URLS:
    • *.emerson.com
    • *.ni.com
Note: These URLs may be accessible via a browser or via ping and still not accessible to Nigel. A Nigel connection is more restrictive than a browser and requires validating certificates to encrypt the data.
Remove proxy variables:
  • Use the following document to check if you have any environmental variables configured: How to Identify Proxy Settings That Affect NI Software Communication.
  • If a proxy variable exists, such as HTTP_PROXY or HTTPS_PROXY, Nigel may not work as expected. Those Environment Variables should be either not set, or the NO_PROXY environment variable should be set to localhost, 127.0.0.1.
You may need to reset your Nigel login after applying these changes.
Please see Configuring Software and Hardware Firewalls to Support NI Products for additional details.
As of 2026, the underlying models used in Nigel are OpenAI models. Nigel never stores your data or uses it for training large language models. See NI Nigel AI for Test & Measurement Workflows for terms and conditions and for information on the current AI models supported by Nigel.
