Missing Example and VI of LabVIEW Toolkit Version 2026 Q1 in LabVIEW 2025 Q3
Updated Apr 13, 2026
  • LabVIEW VI Analyzer Toolkit
  • Database Connectivity Toolkit
  • I am using LabVIEW 2025 Q3, and I realize some of my Report Generation Toolkit's VI and examples are missing from LabVIEW. The Report Generation Toolkit version I am using is 2026 Q1. Is LabVIEW 2025 Q3 compatible with Report Generation Toolkit 2026 Q1?
  • I have installed LabVIEW VI Analyzer Toolkit 2026 Q1 for my LabVIEW 2025 Q3, but it's VIs are nowhere to be found in the block diagram's function palette.
  • After installing LabVIEW 2026 Q1 with it's Database Connectivity Toolkit, my LabVIEW 2025 Q3 no longer has the Database Connectivity Toolkit's VIs. I found my Database Connectivity Toolkit in NI Package Manager and it's version 2026 Q1. Does this means Database Connectivity Toolkit 2026 Q1 is not compatible with LabVIEW 2025 Q3?
Bug in NI LabVIEW Toolkits 2026 Q1 is causing compatibility issue with LabVIEW 2025 Q3.
To resolve this issue, there are two approaches:
  1. Install NI LabVIEW Toolkits 2026 Q3. The bug has been fixed and is now compatible with LabVIEW 2025 Q3.
  2. Manually update lvaddoninfo.json:
    1. Launch text editor software, such as Notepad as an administrator.
    2. Navigate to C:\Program Files\NI\LVAddons
    3. Open the folder of the LabVIEW toolkit(s) experiencing the issue. Below is the acronym of each of the LabVIEW toolkits:
      LabVIEW Toolkit Acronym
      Advanced Signal Processing Toolkitaspt
      Database Connectivity Toolkitdct
      Desktop Execution Trace Toolkitdett
      DataFinder Connectivity VIs dfc
      Digital Filter Design Toolkitdfdt
      Report Generation Toolkitrgt
      Unit Test Framework Toolkitutf
      VI Analyzer Toolkitviawin
    4. Right-click lvaddoninfo.json within the toolkit's folder and select Properties.
    5. Uncheck Read-only attributes, then select Apply and OK
    6. Open with administrator privileges lvaddoninfo.json using text editor.
    7. Change the MinimumSupportedLVVersion value to 25.0 as illustrated below and save.
    8. Restart LabVIEW
Some toolkits have additional folders such as dct32 and dct64. Kindly update the lvaddoninfo.json within the additional folders too.
