LabVIEW 2025 Cannot Switch Class Property Node Write to Read Dynamic Accessors
Updated Mar 11, 2026
In LabVIEW 2025, a software issue prevents users from switching a LabVIEW Class Property Node from Write mode to Read mode when the property is implemented using dynamic accessor VIs.
When creating a New VI for Data Member Access for a LabVIEW class, select Numeric, Read and Write, Dynamic Accessor, and Make available through property nodes = True, as shown in the screenshot.
When placing this class in a new VI and creating a property node for the class, right‑clicking the property node shows that Change to Read and Change All to Read are grayed out.
The workaround is to:
Create the Read Accessor VI first
Then create the Write Accessor VI
A fix is planned in LabVIEW 26.3.0.163-0+d163
