Analyzing a LabVIEW™ Project With NI Nigel™ AI
Updated Aug 1, 2026
  • Nigel AI Integration
If you are shared with LabVIEW Project that you didn't work with and want to generate a full analysis of the project to gain more context you can do that with Nigel AI. In this article you are going to learn use this functionality of Nigel AI.
To get a description of the project by Nigel AI follow the next steps:
  1. Open the project you want to analyze.
  2. Right click the project and then select Discuss with Nigel...
  3. After that Nigel AI is going to automatically create the prompt Describe [project name].lvprj. You also can manually enter the prompt if you have the project open in memory. Be sure to add the .lvproj extension in the prompt.
After following the steps this is going to be the result Nigel AI is going to provide:
