Aurora Support and LabVIEW Sample Projects for PXIe‑7890 / PXIe‑7981
Updated Mar 4, 2026
  • PXIe-7890
  • PXIe-7891
Does the PXIe‑7890 (and PXIe‑7981) support the Aurora protocol through NI‑provided CLIP or sample projects? Are there sample projects available?
Yes. For the PXIe‑7890, NI provides an official Aurora‑based sample and CLIP. Although the NI Example Finder does not list PXIe‑7890 or PXIe‑7891 under the searchable hardware options, you can generate the sample project manually.
To access the Aurora sample project:
  1. Open LabVIEW.
  2. Navigate to:
    Hardware Input and Output → FlexRIO → Integrated IO → Getting Started → Getting Started FlexRIO Integrated IO.vi
  3. Launching this VI will create the full sample project that includes the Aurora CLIP for PXIe‑7890.
This method provides a valid Aurora reference design even though the device does not appear in the Example Finder’s supported hardware list.
