Using the PCIe‑8398 in a Open-Ended PCIe x8 Slot
Updated May 19, 2026
  • PCIe-8398
My computer has a PCIe slot with an x8 physical size. Since the slot is open‑ended, the PCIe‑8398 fits mechanically. Will the card operate correctly in this type of slot?
The PCIe‑8398 is a full‑length x16 PCI Express card, and it can operate in any PCIe slot that physically accepts a card with an x16 edge connector. This includes x16‑sized slots that are only wired for fewer lanes, as well as open‑ended slots that allow full‑length cards to be inserted.
PCI Express automatically trains the link to the highest number of lanes supported by both the device and the slot, so the PCIe‑8398 will operate normally even if the slot provides fewer lanes.
Using fewer PCIe lanes reduces bandwidth proportionally, so an x8 slot cuts the PCIe‑8398’s throughput to half of x16 operation.
Some motherboards may negotiate an even lower link width, so an electrically x16 slot is recommended for maximum MXI performance.
Although the PCIe‑8398 can operate in reduced‑lane configurations, this may limit total MXI system throughput. If system bandwidth is critical for the application, NI recommends using a slot that is both mechanically and electrically x16. For any MXI‑related issues, refer to the MXI-Express Compatibility and Connectivity Troubleshooting Guide.
