Build Process Use More Memory in Latest Versions of LabVIEW
Updated Feb 25, 2026
When moving from older LabVIEW versions (such as 2017) to newer releases, I may notice that application builds require significantly more memory. In some cases, this can lead to build slowdowns or Not enough memory errors. This behavior can occur even if my application source code has not changed.
Why Newer LabVIEW Versions Use More Memory During Builds and How to Reduce It?
Modern LabVIEW versions load and process more information during compilation. Newer compilers work with larger dependency graphs, more complex project structures, and richer data types. As a result, the Application Builder consumes more RAM while preparing, recompiling, and linking project components.
Note that large or complex projects naturally require more RAM during builds, and the compiler may run out of memory when handling these expanded dependency sets.
In addition, the build process may trigger full recompilation of VIs, which increases in‑memory requirements during the early build stages. Clearing caches and recompiling the project ahead of time helps minimize these memory spikes.
Even when your project files are unchanged, differences in the internal compiler and build pipeline between older and newer LabVIEW versions can result in higher RAM usage.
Recommended Actions
