I recently acquired an NI Linux Real-Time (RT) controller and installed the software on a PC to start programming it. However, when I try to create a new project in LabVIEW using the LabVIEW Real-Time Control (NI-DAQmx) or LabVIEW Real-Time Waveform Acquisition and Logging (NI-DAQmx) sample project templates, error 74 is always generated when trying to create the project as shown below:
Error 74 occurred at Invoke Node in NI_NPW_Project Copying.lvlib:CopyUserProject.vi->NI_NPW_Project Copying.lvlib:CreateUserProject.vi->NewProjectDialog.vi
Possible reason(s):
LabVIEW:(Hex 0x4A) Memory or data structure corrupt.
Method Name: Project:Open
Furthermore, if I try to open a project that already uses a NI Linux RT target, LabVIEW does not display its IP address nor the connectivity indicator (green LED) next to the controller's icon in the Project Explorer Window, and the Properties Dialog Box for the target is completely empty.
