Replace vs Paste-Replace in LabVIEW: Understanding the Difference
Updated Apr 29, 2026
LabVIEW provides two ways to change an existing control, indicator, or object on the front panel or block diagram: Replace and Paste‑Replace. Although they appear similar, they behave very differently. When should I use each operation?
What is Replace?
The Replace operation swaps the selected object with another object chosen from the palette. LabVIEW intentionally preserves many attributes of the original object.
For example, if you replace a Fuse Numeric control that has a blue background color, LabVIEW applies that same background color to the new control, as shown in the screenshot below. This shows how Replace attempts to maintain visual and behavioral continuity from the original item.
How to Use Replace (Palette Method):
  1. Right‑click the object you want to replace.
  2. Select Replace.
  3. Choose the new control, indicator, or function from the temporary palette.
  4. LabVIEW replaces the object while preserving the old one’s properties.
How to Use Replace (Quick Drop Replace):
Replace can also be performed using Quick Drop, which is often faster and more scalable:
  1. Select the object you want to replace.
  2. Press Ctrl+Space to open Quick Drop.
  3. Type the name of the new control, indicator, or function.
  4. Press Ctrl+P to perform a Quick Drop Replace.
LabVIEW replaces the selected object while preserving applicable properties from the original object, just like the palette-based Replace.
Tip: Quick Drop Replace supports multi-selection. If you select multiple objects before invoking Quick Drop, all selected objects can be replaced at once with the new object, a powerful way to make bulk edits efficiently.
What is Paste‑Replace?
Paste‑Replace replaces the selected object with an exact copy of whatever is currently on the clipboard—without preserving any properties from the original object.
This is fundamentally different from Replace. When you copy a front‑panel object and then select another object and press Ctrl+V, LabVIEW completely swaps the selected item with the clipboard object as-is, maintaining none of the original object’s characteristics.
How to Perform a Paste‑Replace:
  1. Copy an object using EditCopy or Ctrl+C.
  2. Select the object you want to replace.
  3. Press Ctrl+V.
  4. The object on the clipboard completely replaces the selected object.
When to Use Paste‑Replace:
Use Paste‑Replace when you want:
  • A full replacement
  • The new object’s properties to override everything
  • To avoid any inherited look, settings, or metadata from the original object
This is especially useful when the original control has unwanted formatting (e.g., colors, styles, captions) and you want to start clean.
  • Replace is ideal for changing control types while keeping consistent formatting.
  • Paste‑Replace is the correct choice when you explicitly want no inherited properties from the original control.
