Programmatically Change TestStand Process Model Options
Updated Oct 22, 2026
  • TestStand
I am using the TestStand Parallel Process Model and need to programmatically modify the process model settings through the TestStand API.
For the process models included with NI TestStand™ (Sequential, Parallel, and Batch), use the ModelOptions sequence file callback to override process model settings programmatically.
Perform the following steps:
  1. Open NI TestStand and select the sequence file.
  2. Navigate to Sequences and select Sequence File Callbacks...
  3. Enable ModelOptions.
  4. Edit the variables in the ModelOptions callback to override the desired process model settings.
The modified values are applied when the process model executes.
The ModelOptions callback is available for the standard process models shipped with NI TestStand, including the Sequential, Parallel, and Batch process models.
