Does NI 9862 Support 33.33 kBaud rate ?
Updated Feb 13, 2026
  • NI-9862
  • PXI-8513
  • PCI-8513
  • NI-XNET
When I create XNET database, I can select 33.33 kBaud rate as CAN cluster property.
Is this baud rate available in NI 9862 which supports High Speed CAN ?
No, NI 9862 does not support 33.33 kBaud rate. When you use 33.33 kBaud rate XNET database with hardware which does not support single wire CAN, error -1074384779 occurs.
If you want to use this baud rate, single wire CAN communication should be selected. PXI/PCI-8513 support single wire CAN.
