Refer to the following example file included in LabVIEW.
C:\Program Files\National Instruments\LabVIEW 20xx\examples\Design Patterns\Registration Map
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project.
To use a snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW block.
