Writing and Debugging Expressions in Teststand
Updated Feb 11, 2026
  • TestStand
  • How can I manipulate or compute values inside TestStand without writing a code module?
  • What is the correct syntax for writing expressions in TestStand, and what operators or functions can I use?
  • How do I modify step results, variables, or TestStand API objects using expressions?
Expressions are a core part of TestStand and are used to compute values, make decisions, modify data, and interact with the TestStand API during sequence execution. They appear in many places throughout the environment, including step properties, conditions, limits, callbacks, Tools Menu utilities, and more.
This KB provides a practical guide on how to write, structure, and debug TestStand expressions, focusing on programming techniques and real‑world usage. It is divided into the following sections:
For reference-level syntax documentation, see the Expressions section of the TestStand Help and the TestStand API Reference Guide.
What Are TestStand Expressions?
A TestStand expression is a formula that evaluates to a value or performs an action such as an assignment, function call, API access, or conditional decision. Expressions use syntax familiar to C, C++, Java, and Visual Basic .NET. See below a few examples of expressions.
Example 1: Calculates a midpoint frequency during sequence execution:
Locals.MidBandFrequency = (Step.HighFrequency + Step.LowFrequency) / 2
Example 2: Sets Locals.ChamberStatus based on the comparison between Locals.CurrentTemperature and Locals.Threshold:
Locals.ChamberStatus = (Locals.CurrentTemperature > Locals.Threshold) ? "Overheating" : "Normal"
Example 3: Posts a user message to the Operator Interface to plot an array of data:
RunState.Thread.PostUIMessageEx(UIMsg_UserMessageBase + 10, 0, "PlotData", Locals.Data, False)
Editor Assistance When Writing Expressions
TestStand includes several features designed to make writing expressions easier, more discoverable, and less error‑prone.
Auto-Completion (Ctrl+Space)
Pressing Ctrl+Space opens a drop‑down list of valid expression elements, including:
  • Variables and properties
  • Functions
  • Operators
  • TestStand API objects and methods
auto-completion drop-down list that shows when you hit ctrl+space
This list also appears automatically when you press the dot (.) key to access subproperties. Subproperties appear at the top of the list, while TestStand API methods applicable to the current object appear below. You can toggle the display of TestStand API suggestions by selecting Hide TestStand API or Show TestStand API.
auto-complete list shown when you press dot.
This feature works similarly to IntelliSense, helping prevent typing mistakes and speeding up expression creation.
Function Tips
Hovering over a function name displays the function signature, a brief description and any existing run-time error.
Function Tip Ballon
In addition to that, as you start typing the parameters, the Function Tip shows up and updates automatically, highlighting the active parameter in bold and advancing to the next parameter when you type a comma. It also includes a link to the function page in the TestStand Help.
function tip
You can also open it by right‑clicking the function and selecting Function Tip.
Delimiter Matching and Navigation
Expressions often involve nested parentheses, brackets, or braces. TestStand provides:
  • Automatic bolding of matching delimiters
  • Ctrl + ] to jump to the matching delimiter
  • Ctrl + Shift + ] to select everything between matching delimiters
Expression Browser
The Expression Browser provides an interactive UI for constructing, inspecting, and validating expressions. It exposes variables, operators, functions, and the full TestStand API for selection, reducing the need to memorize syntax or object paths. It can be accessed from any expression field, by clicking the button f(x) .
Expression browser dialog
Tip: Review the Operators/Functions tab to discover built‑in functions that may eliminate the need for code modules or simplify existing module logic.
When creating expressions, you might come across errors or unexpected results. See next some debugging tools and tips you can use to help you fix your expressions.
Use the Watch View Pane
You can watch variables or property expressions during execution. Be mindful: modifying properties in the Watch View can change execution behavior.
watch view pane
To remove watch expressions, go to Debug >> Breakpoints/Watches >> Watch Expressions tab
Use “Check Expression for Errors…
The **Check Syntax** button ✓validates expressions before runtime. If your expression references properties created at runtime, wrap it in #NoValidation() to avoid false positives.
Best Practices for Writing Clean Expressions
Adding Comments in Expressions
Expressions support several comment styles that are useful for documentation, explanation, and debugging.
// C++ style comment
' Basic‑style comment
/* Multi‑line
block comment */
Use cases include:
  • Describing complex logic
  • Disabling sections temporarily
  • Documenting API calls or unusual syntax
Combining Multiple Expressions
TestStand can evaluate multiple expressions in sequence using commas.
Example:
Locals.A = Locals.B + 1,
Locals.Result = Locals.A * 2
This enables multi‑step logic without requiring multiple Statement steps or a code module. It is also helpful for breaking complex logic into smaller, readable fragments.
Avoid Overly Complex Expressions
If an expression grows large enough that you find yourself spending extra time trying to understand or follow the logic, consider breaking it into smaller, more focused pieces and placing them in separate Statement steps. This approach improves readability, reduces cognitive load, and makes debugging significantly easier.
