When I connect a PXIe-6674T on my chassis timing slot does this automatically replace the chassis internal oscillator with the timing card's internal OCXO oscillator? The documentation states that if a 10 MHz reference is detected on the PXI_CLK10_IN connector, the chassis will replace its internal 10 MHz backplane clock with the external source, but it is not explicitly stated whether installing a PXI timing card automatically triggers this override as well.
