TestStand Test Result Saved as Garbled Characters in MySQL
Updated Feb 5, 2026
  • TestStand
My test program consists of Unicode characters. I found that test results with Unicode characters are saved as garbled in the MySQL database. How can I avoid this and have the test result saved as Unicode character in the MySQL database?
Incorrect database string expression might have caused the Unicode character to be saved wrongly. Kindly ensure the MySQL ODBC Unicode driver is used instead of the ANSI version. Below is a sample of the database string expression using MySQL ODBC Unicode driver.
Driver={MySQL ODBC <version> Unicode Driver};Server=<server IP>;Database=<database name>;User=<user name>;password=<password>
