I've provided the power to the cDAQ-9178, but the POWER LED is not lit, it's the same with the READY LED. The ACTIVE LED is amber.
Is this hardware failure?
Yes, if the power supply is normal but POWER LED on cDAQ-9178 is not lit, it must be hardware failure. Raise a RMA request via ni.com or contacting NI.
Three status LEDs are on cDAQ-9178: POWER, ACTIVE and READY.
