Turn off Nigel™ AI Code Completion in LabVIEW™
Updated Mar 27, 2026
  • LabVIEW Professional
Programming Language
  • LabVIEW G
How do I disable the Nigel AI code completion wiring target (located on the block diagram: ) in LabVIEW 2026 Q1 and later?
To turn off the Nigel AI code completion feature, you will need to edit the LabVIEW.ini file to include following entry:
Wiring.CodeCompletionTarget.Enabled=FALSE
This line can be placed anywhere in the LabVIEW.ini file. If LabVIEW is open, you will need to restart LabVIEW for the changes to come into effect.
The LabVIEW.ini file is located in the LabVIEW installation folder:
  • LabVIEW (64-bit): C:\Program Files\National Instruments\LabVIEW [Version]
  • LabVIEW (32-bit): C:\Program Files (x86)\National Instruments\LabVIEW [Version]
