Ensuring Safe Use of Custom FPGA Images on USRP
Updated Mar 2, 2026
  • Ettus USRP X410
I am planning to deploy a custom FPGA image, including Programmable Logic (PL) and Processing System (PS) modifications, on the USRP. I want to understand which precautions and constraints must be followed so that hardware operation remains within device specifications and does not violate the warranty. I am specifically concerned about how custom I/O configurations, power consumption, and thermal behavior may affect the device.
A custom FPGA image does not void the USRP warranty as long as the device is operated within the electrical, thermal, and functional limits defined in the component datasheets. Hardware damage caused by exceeding those limits is not covered under warranty.
Follow the guidance below to remain within warranty‑safe operating conditions.
1. Maintain Valid Electrical Operating Conditions
Misconfiguration or misuse of FPGA I/O is the most common way a custom image can cause hardware damage.
Perform the following actions:
  • Review the FPGA and peripheral component datasheets for I/O voltage, current, and temperature specifications.
  • Verify that the custom design does not modify or override FPGA I/O standards used by on‑board peripherals.
  • Confirm that pin assignments, drive strengths, or termination settings do not exceed allowable electrical ratings.
  • Ensure that no external interfaces are driven in a manner incompatible with the board’s hardware design.
If the custom bitfile does not alter I/O behavior or electrical characteristics, the risk of hardware damage is low.
2. Monitor Thermal and Power Conditions
Increased FPGA resource utilization may lead to additional heat and power consumption.
  • Monitor on‑board FPGA temperature sensors exposed through available system utilities.
  • Verify that the operating temperature remains within limits stated in the FPGA datasheet.
  • Confirm safe operation especially when ambient temperature is near the high end of the USRP X410 rating.
3. Use NI-Provided Toolflows Where Possible
NI encourages the use of custom FPGA designs on USRP devices, and the USRP X410 is intended to support user‑programmable logic.
  • Build and modify FPGA DSP logic through the UHD (USRP Hardware Driver) and RFNoC (RF Network‑on‑Chip) development toolflows.
  • Utilize these frameworks to ensure that static infrastructure and protected hardware control logic remain within safe operational bounds.
These toolflows provide a controlled “window” into the FPGA fabric, reducing the likelihood of inadvertently causing electrical or functional misuse.
Refer to the Xilinx device datasheet for FPGA voltage, current, and temperature limits. When evaluating PL/PS modifications, ensure that all programmable interfaces connected to the USRP hardware remain within those specifications.
