Electromechanical switches are not suited for high‑speed switching because they rely on physically moving contacts. Their typical switching rates are around 130–145 cycles per second, which is too slow for applications requiring fast or precise timing. An example of an electromechanical switch is the PXI‑2576.
For higher‑speed performance, reed relays or solid‑state relays (SSRs) are more suitable alternatives. An example of a PXI Switch Module with reed relays configuration is the PXI-2530B which have a switching rate at around 900 cycles per second.
In summary, electromechanical switches are appropriate for low‑speed or general‑purpose applications, but high‑speed switching requires reed‑based or solid‑state solutions.
