NI VST Self-Calibration Error -1074100400 After Upgrading to NI-RFSA/G 2025 Q3
Updated Jan 29, 2026
  • PXI Vector Signal Transceiver
  • NI-RFSA 2025 Q2
  • NI-RFSA 2025 Q1
  • NI-RFSA 2025 Q3
  • NI-RFSG 2025 Q1
  • NI-RFSG 2025 Q2
  • NI-RFSG 2025 Q3
After recently upgrading the NI-RFSA and NI-RFSG drivers to version 2025 Q3, the self-calibration for my Vector Signal Transceiver (VST) is now failing with error -1074100400. However, the intermediate self-test passes and the hardware is still operational. When I look at the 'Self-Cal.log' file located at C:\Users\<LocalAdmin>\AppData\Local\Temp\niVST Cal Results, the detailed error states the following:
[-1074100400]
Generate Curve From Reference Curve.vi:1880001<APPEND>
Frequency array must be monotonic and strictly increasing.
Index 36, Freq 8100000000.000000
How do I resolve this error?
This is a known issue that was found in the earlier versions of the NI-RFSA/RFSG 2025 driver software which has since been fixed.
Please upgrade the NI-RFSA/RFSG drivers to the 2025 Q4 Patch 1 or newer to resolve this issue.
If your VST is still unable to successfully complete the self-calibration after upgrading the drivers, please contact NI Technical Support.
It is recommended to have matching versions of all RF drivers and software installed on your system. If upgrading NI-RFSA, upgrade NI-RFSG to the same version.
