Opening a VeriStand Project Created in a Newer Version is Not Supported in Older Versions
Updated Jan 23, 2026
  • VeriStand
I encounter the following error when trying to open a VeriStand Project created in a newer version using an older version of VeriStand:
"Project path" failed to load because it contains content that was saved in a newer version. The document was last saved in Veristand Version X.X.X.XXXXX Build X.X.X.XXXXX.
This error occurs because the VeriStand project was created in a newer version of VeriStand, which cannot be opened using an older version. VeriStand supports only backward compatibility.
To open the project, you will need to either upgrade VeriStand to the same version or a newer version than the one used to create the project, or manually recreate the project in the older VeriStand environment.
