How to Check Installed NI Software on My Linux Desktop Running RHEL?
Updated Jan 12, 2026
Other
  • Red Hat Enterprise Linux
I am using RHEL as an operating system on which NI Software is installed. I want to check what NI software is installed there.
On RHEL (Red Hat Enterprise Linux), you can list all installed packages using the following command:
rpm -qa
Alternatively, if you are using DNF (the newer package manager for RHEL 8 and later), you can use:
dnf list installed
Sample of running command  rpm -qa
Sample of running command dnf list installed
Next Steps
You can filter packages by name using either rpm or dnf:
rpm -qa | grep <package_name>  or  dnf list installed | grep <package_name>
