Solid Color Tunnel in Diagram Disable Structure While No Wire Connection
Updated Jul 26, 2026
I am designing a LabVIEW code for my application and found that when Diagram Disable Structure is used, even without wire connection, its output tunnel remains solid colour.
I also observed that when the VI with this issue is saved, when it is opened, the following error will prompt:
LabVIEW: (Hex Ox1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
An error occurred loading VI 'bug.vi'.
LabVIEW load error code 3: Could not load front panel.
Is this an expected behaviour? Below is an example of my block diagram:
This is due to a bug in LabVIEW 2025 Q3. It has been resolved in LabVIEW 2026 Q1 (26.1.0.49909-0+f757).
